주요 콘텐츠로 건너뛰기
Asus K55VD RAM Replacement
필요한 것
  1. 주의: 1 단계는 진행 중으로 표시된 안내서에서 제공되었습니다.
    • Power off the device completely
    • Flip the device over to its back cover.
    • Use the switches to release the battery from its adapter.
  2. Asus K55VD RAM Replacement, RAM: 2 단계, 이미지 1/1
    • To access the compartment that holds the RAM, flip the laptop so the bottom cover is facing upward and the battery compartment is facing away from you.
  3. Asus K55VD RAM Replacement: 3 단계, 이미지 1/1
    • Use a Phillips #0 screwdriver to remove the two screws that hold down the compartment cover.
  4. Asus K55VD RAM Replacement: 4 단계, 이미지 1/1
    • Lift the cover and locate the green and blue RAM sticks on the right side of the device.
  5. Asus K55VD RAM Replacement: 5 단계, 이미지 1/3 Asus K55VD RAM Replacement: 5 단계, 이미지 2/3 Asus K55VD RAM Replacement: 5 단계, 이미지 3/3
    • To remove the green RAM stick, push outward on the inner sides of the two metal chip holders simultaneously.
    • Pull out the stick once it is released from the holders.
    • Repeat this step on the lower level that holds the blue RAM stick.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Dahlia Adam
회원 가입일: 09/21/18
260 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 17
전체 시간: 787
