주요 콘텐츠로 건너뛰기
Asus K55a-si50301p Hard Drive Replacement
필요한 것
  1. Asus K55a-si50301p Hard Drive Replacement, Battery: 1 단계, 이미지 1/1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p Hard Drive Replacement: 2 단계, 이미지 1/1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p Hard Drive Replacement: 3 단계, 이미지 1/1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p Hard Drive Replacement, Lower Back Panel: 4 단계, 이미지 1/1
    • Remove the two 8.5mm screws using a PH0 screwdriver.
  5. Asus K55a-si50301p Hard Drive Replacement: 5 단계, 이미지 1/1
    • Using the iFixit opening tool, gently pry the plastic cover away from its original position.
  6. Asus K55a-si50301p Hard Drive Replacement: 6 단계, 이미지 1/1
    • Gently pull up and then towards you until the plastic cover is free.
  7. Asus K55a-si50301p Hard Drive Replacement, Hard Drive: 7 단계, 이미지 1/2 Asus K55a-si50301p Hard Drive Replacement, Hard Drive: 7 단계, 이미지 2/2
    • Remove the (3) screws that hold the hard drive to the case.
  8. Asus K55a-si50301p Hard Drive Replacement: 8 단계, 이미지 1/2 Asus K55a-si50301p Hard Drive Replacement: 8 단계, 이미지 2/2
    • Disconnect the SATA link from the hard drive by pulling back on the grey connector.
  9. Asus K55a-si50301p Hard Drive Replacement: 9 단계, 이미지 1/1
    • Remove the two screws from each side of the hard drive tray.
    • Replace the hard drive with a new 2.5" hard drive or solid state drive.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Christian Bocanegra
회원 가입일: 02/12/19
273 평판
안내서 2개 작성하였습니다
댓글 한 개
So the link you give for the replacement hard drive is for a 3.5 inch drive instead of a 2.5 inch drive
sweal - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 17
전체 시간: 1,101
