소개
The Asus K55A-Si50301P Hard Drive Replacement Guide explains the tools and process used to replace/remove the Hard Drive as needed. The hard drive may occur to be damaged/faulty when general hardware such as screws become loose and release the drive from its connection. The Asus K55A-Si50301P Troubleshooting page may be referred to hereas needed.
필요한 것
Press and slide the two battery retention clips on either side of the battery towards the unlock position.
다른 4명이 해당 안내서를 완성하였습니다.
