주요 콘텐츠로 건너뛰기
Asus K55a-si50301p Wifi Card Replacement
필요한 것
  1. Asus K55a-si50301p Wifi Card Replacement, Battery: 1 단계, 이미지 1/1
    • Press and slide the two battery retention clips on either side of the battery towards the unlock position.
  2. Asus K55a-si50301p Wifi Card Replacement: 2 단계, 이미지 1/1
    • Pull the right side retention clip so that the red indicator is showing.
    • The small graphic below the retention clip denotes locked and unlocked positions. The clip will stay put once moved into position.
  3. Asus K55a-si50301p Wifi Card Replacement: 3 단계, 이미지 1/1
    • Pull the retention clip on the left hand side of the laptop away from the battery.
    • Gently pull the battery out with your free hand.
  4. Asus K55a-si50301p Wifi Card Replacement, Lower Back Panel: 4 단계, 이미지 1/1
    • Remove the two 8.5mm screws using a PH0 screwdriver.
  5. Asus K55a-si50301p Wifi Card Replacement: 5 단계, 이미지 1/1
    • Using the iFixit opening tool, gently pry the plastic cover away from its original position.
  6. Asus K55a-si50301p Wifi Card Replacement: 6 단계, 이미지 1/1
    • Gently pull up and then towards you until the plastic cover is free.
  7. Asus K55a-si50301p Wifi Card Replacement, Wifi Card: 7 단계, 이미지 1/1
    • Remove the white and black wires from the card.
    • This does not require much force. Simply squeeze on the sides of the connector and allow the end to pop off.
  8. Asus K55a-si50301p Wifi Card Replacement: 8 단계, 이미지 1/1
    • Remove the two 9mm Phillips #1 screws from the wifi card.
  9. Asus K55a-si50301p Wifi Card Replacement: 9 단계, 이미지 1/1
    • After unscrewing lift gently to remove.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Zack Cannon
회원 가입일: 02/07/19
359 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 811
