소개
The battery is the device's power source. This device has a rechargeable battery. Sometimes when devices are plugged in while in use or plugged in for too long, it can shorten the battery life. This is one of the most replaced components. Luckily this is one of the simplest to replace.
필요한 것
Gently wedge a Jimmy into the seam of the device.
Gently pry the Jimmy all around the seam until the back panel is detached.
다른 2명이 해당 안내서를 완성하였습니다.
