주요 콘텐츠로 건너뛰기
Asus MeMO Pad 7 ME170C Battery Replacement
필요한 것
  1. Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: 1 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: 1 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Battery Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Before beginning to disassemble, Power off the device.
    • Excessive force can result in damaged or cracked screen. Be Gentle.
    • Gently wedge a Jimmy into the seam of the device.
    • Gently pry the Jimmy all around the seam until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C  Battery Replacement: 2 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Battery Replacement: 2 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Battery Replacement: 2 단계, 이미지 3개 중 3개
    • Locate the black bundle cable connector attached to the battery of the phone.
    • Do not push down. Slide in a forward motion to avoid breaking any inner pieces.
    • Using a plastic opening tool, gently slide the black bundle cable connector towards the battery in a back and forth motion until loosened and it slides out of connection port.
  3. Asus MeMO Pad 7 ME170C  Battery Replacement: 3 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Battery Replacement: 3 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Battery Replacement: 3 단계, 이미지 3개 중 3개
    • Using a plastic opening tool, pry out the batteries to loosen them out.
    • The battery will be pried out of its port.
    • Lift the battery out of its port
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
8다른 기여자 명과 함께
Veronica Dalton
회원 가입일: 10/08/15
120 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 3
지난 30일: 8
전체 시간: 3,325
