주요 콘텐츠로 건너뛰기
Asus MeMO Pad 7 ME170C Motherboard Replacement
필요한 것
  1. Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: 1 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: 1 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement, Motherboard: 1 단계, 이미지 3개 중 3개
    • Power off the device before disassembly.
    • Be gentle; excessive force can result in a damaged or cracked screen.
    • Gently pry a Jimmy all around the seam of the device until the back panel detaches.
  2. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 2 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 2 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 2 단계, 이미지 3개 중 3개
    • Use an iFixit opening tool to gently push the black bundle cable connector in a forward motion until it loosens without pushing down on the bundle cable connector.
  3. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 3 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 3 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 3 단계, 이미지 3개 중 3개
    • Use the plastic opening tool to pry around the edges of the battery.
    • The battery should be laying freely in its port.
    • Lift the battery out of its port.
  4. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 4 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 4 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 4 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to slide the white cable connector completely out of the port.
  5. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 5 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 5 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Flip up the beige clip to loosen the cable.
    • Use the wide nosed tweezers to pinch the blue tab attached to the ribbon cable.
    • Pull the blue tab gently in a lateral motion until it is completely out of its port.
  6. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 6 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 6 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 6 단계, 이미지 3개 중 3개
    • Use the wide nosed tweezers to gently pull out the orange ribbon inserted in the port on the motherboard.
  7. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 7 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 7 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 7 단계, 이미지 3개 중 3개
    • Use a plastic opening tool to push the white cable connector out of its port in a side to side motion.
  8. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 8 단계, 이미지 2개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 8 단계, 이미지 2개 중 2개
    • Use the Phillips #000 screwdriver to unscrew the seven screws.
    • There should be two silver and five black screws.
  9. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 9 단계, 이미지 2개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 9 단계, 이미지 2개 중 2개
    • Once the screws are removed, the speaker component will be loosely laying in the track.
    • Use the metal spudger tool to remove the speaker by gently lifting the edge of it.
  10. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 10 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 10 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 10 단계, 이미지 3개 중 3개
    • Remove the silver tape on one corner with the needle nosed tweezers, and remove the tape from the motherboard.
  11. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 11 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 11 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 11 단계, 이미지 3개 중 3개
    • Use the needle nosed tweezers to gently pull both of the orange ribbon cables out of their ports.
  12. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 12 단계, 이미지 3개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 12 단계, 이미지 3개 중 2개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 12 단계, 이미지 3개 중 3개
    • Use the Phillips #000 screwdriver to unscrew all five screws.
  13. Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 13 단계, 이미지 2개 중 1개 Asus MeMO Pad 7 ME170C  Motherboard  Replacement: 13 단계, 이미지 2개 중 2개
    • To uninstall the motherboard, use the metal spudger tool to lift it out of the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
작성자
11다른 기여자 명과 함께
Tatiana Schneider
회원 가입일: 10/04/15
599 평판
안내서 4개를 작성함
1가이드 댓글
You are amazing!! Please make the tutorial "how change ASUS ME170 Touch Screen Digitizer". Thanks!!!
Walter Tejerina - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 10
전체 시간: 3,505
