소개
The power button is how the device's power source is turned on. This device has a an integrated power and volume button. Sometimes the button becomes damaged after excessive use or pressure and no longer works. This is one of the simplest components to replace.
필요한 것
Gently wedge a Jimmy into the seam of the device.
Gently pry the Jimmy all around the seam until the back panel is detached.
Locate the cable that connects the power button to the motherboard.
Carefully lift and release the connector lock that keeps it attached the motherboard. The connector lock rotates up away from the connection to release.
Carefully release the connection from the motherboard.
Gently pry the power and volume button away from the case. There should not be much resistance when prying the button off.
