주요 콘텐츠로 건너뛰기
Asus MeMO Pad 7 ME170C Speaker Replacement
필요한 것
  1. Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: 1 단계, 이미지 1/3 Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: 1 단계, 이미지 2/3 Asus MeMO Pad 7 ME170C Speaker Replacement, Speaker: 1 단계, 이미지 3/3
    • Before beginning to disassemble the device, power it off.
    • Make sure to be gentle with the device. Excessive force can result in a damaged screen.
    • Using the Jimmy tool, gently wedge it into the seam of the device at the side.
    • Pry the Jimmy tool gently all around the seam. Use up and down motions until the back panel is detached.
  2. Asus MeMO Pad 7 ME170C Speaker Replacement: 2 단계, 이미지 1/3 Asus MeMO Pad 7 ME170C Speaker Replacement: 2 단계, 이미지 2/3 Asus MeMO Pad 7 ME170C Speaker Replacement: 2 단계, 이미지 3/3
    • From the top of the tablet, locate the white cable connector.
    • It is inserted in a black port on the motherboard.
    • Use the blue plastic opening tool to push the white cable connector out of the port.
    • Push the cable in a sideways motion towards the top of the device.
  3. Asus MeMO Pad 7 ME170C Speaker Replacement: 3 단계, 이미지 1/2 Asus MeMO Pad 7 ME170C Speaker Replacement: 3 단계, 이미지 2/2
    • Use the Phillips #000 screwdriver to remove the seven screws.
    • There should be two silver and five black screws for a total of seven screws.
  4. Asus MeMO Pad 7 ME170C Speaker Replacement: 4 단계, 이미지 1/2 Asus MeMO Pad 7 ME170C Speaker Replacement: 4 단계, 이미지 2/2
    • Use the slender, metal spudger tool to gently lift up the edge of the speaker to remove the device.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tatiana Schneider
회원 가입일: 10/04/15
599 평판
안내서 4개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 7
30일 전: 10
전체 시간: 680
