주요 콘텐츠로 건너뛰기
Asus MeMO Pad 7 ME176C Battery Replacement
필요한 것
  1. Asus MeMO Pad 7 ME176C Battery Replacement, Battery Replacement: 1 단계, 이미지 1/1
    • Make sure the device is turned off.
    • Use a plastic opening tool to remove the back panel by carefully moving the tool around the back cover of the device until it comes off.
  2. Asus MeMO Pad 7 ME176C Battery Replacement: 2 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C Battery Replacement: 2 단계, 이미지 2/2
    • Locate the black bundle connector on the back of the device. Gently slide the plastic tool underneath the black bundle cable connector towards the battery until it comes off.
  3. Asus MeMO Pad 7 ME176C Battery Replacement: 3 단계, 이미지 1/3 Asus MeMO Pad 7 ME176C Battery Replacement: 3 단계, 이미지 2/3 Asus MeMO Pad 7 ME176C Battery Replacement: 3 단계, 이미지 3/3
    • Using the plastic opener tool, carefully remove the ZIF connectors that is covering the battery.
  4. Asus MeMO Pad 7 ME176C Battery Replacement: 4 단계, 이미지 1/3 Asus MeMO Pad 7 ME176C Battery Replacement: 4 단계, 이미지 2/3 Asus MeMO Pad 7 ME176C Battery Replacement: 4 단계, 이미지 3/3
    • Wedge the flat end of a spudger or plastic opening tool under the battery to free the battery form any adhesives.
    • Do not bend or puncture the battery.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Benjamin von Furstenrecht
회원 가입일: 09/26/17
164 평판
안내서 1개 작성함
Cal Poly, Team S6-G3, Banghart Fall 2017 Cal Poly, Team S6-G3, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G3
5 회원들
안내서 9개 작성하였습니다
댓글 한 개
It might be better to remove the whole aluminum tray under the battery. It is really tough to slice the tape holding the battery to the tray without bending up the battery or putting a lot of pressure on the circuit board. It looks like nine screws and a couple extra steps.
Jim80686 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 2,197
