주요 콘텐츠로 건너뛰기
Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement
필요한 것
  1. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: 1 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement, LCD Screen Assembly: 1 단계, 이미지 2/2
    • Insert plastic opening tool in between screen and back cover to create initial separation between the two.
    • Then run plastic opening tool along end of screen to fully separate back cover from screen.
  2. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 2 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 2 단계, 이미지 2/2
    • Remove screws (2.6mm) connecting speaker to hard frame with Phillips head screw driver (PH000).
  3. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 3 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Disconnect speaker wire from motherboard using metal pronged tweezers.
  4. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 4 단계, 이미지 1/1
    • Remove the screws (2.6mm) connecting the motherboard and battery tray to the hard frame with Phillip's head screw driver (PH000).
  5. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 5 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 5 단계, 이미지 2/2
    • Remove the black bundle battery connector from the motherboard using plastic opening tools.
  6. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 6 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 6 단계, 이미지 2/2
    • Use plastic opener tool to disconnect ZIF connectors as shown.
  7. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 7 단계, 이미지 1/3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 7 단계, 이미지 2/3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 7 단계, 이미지 3/3
    • Remove speaker housing to expose ZIF connection underneath.
    • Then using metal tweezers disconnect the ZIF connector.
  8. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 8 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 8 단계, 이미지 2/2
    • Remove display and button connections from motherboard using metal tweezers.
  9. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 9 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 9 단계, 이미지 2/2
    • Remove unscrewed battery tray from main frame.
  10. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 10 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 10 단계, 이미지 2/2
    • Remove motherboard from hard frame.
    • When removing the motherboard make sure all screws that attach motherboard to hardframe are removed and to release plastic tab as shown in image.
  11. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 11 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 11 단계, 이미지 2/2
    • Peel off button sensors off the side of the hard frame.
  12. Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 12 단계, 이미지 1/3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 12 단계, 이미지 2/3 Asus MeMO Pad 7 ME176C LCD Screen Assembly Replacement: 12 단계, 이미지 3/3
    • Apply slight pressure on camera to break adhesive to finish screen disassembly processes.
결론
Nejad Harara
회원 가입일: 09/26/17
110 평판
안내서 1개 작성함
Cal Poly, Team S6-G3, Banghart Fall 2017 Cal Poly, Team S6-G3, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G3
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 10
전체 시간: 1,686
