주요 콘텐츠로 건너뛰기
Asus MeMO Pad 7 ME176C Motherboard Replacement
필요한 것
  1. Asus MeMO Pad 7 ME176C Motherboard Replacement, Motherboard: 1 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C Motherboard Replacement, Motherboard: 1 단계, 이미지 2/2
    • Before taking anything apart, first make sure the device is turned completely off.
    • The device is somewhat fragile so beware not to put too much force on the screen.
    • Use a opening tool to pry open the backside cover of the device. Gently pry the backside open all around.
  2. Asus MeMO Pad 7 ME176C Motherboard Replacement: 2 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C Motherboard Replacement: 2 단계, 이미지 2/2
    • Locate a black connector that is attached from the battery to the motherboard.
    • Gently slide the connector out with the opening tool by pushing it back, to avoid damaging any part.
  3. Asus MeMO Pad 7 ME176C Motherboard Replacement: 3 단계, 이미지 1/3 Asus MeMO Pad 7 ME176C Motherboard Replacement: 3 단계, 이미지 2/3 Asus MeMO Pad 7 ME176C Motherboard Replacement: 3 단계, 이미지 3/3
    • Locate the battery and area where a strip of wire is connected to the motherboard.
    • Use a nylon spudger or something which you can easily push back and slide the wire out carefully from the motherboard connector.
    • Then peel back the tape connecting the wire to the battery on both ends and lift the wire off the battery.
    • Gently slide a plastic spudger between the battery and the housing to free the adhesive. Work the spudger from side to side to gradually free the battery.
    • Do not use a metal tool to remove the battery; avoid bending or puncturing the battery during removal.
  4. Asus MeMO Pad 7 ME176C Motherboard Replacement: 4 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C Motherboard Replacement: 4 단계, 이미지 2/2
    • On the right side of the tablet there is a small black connector.
    • Using a small tool, carefully slide back the connector from the motherboard.
  5. Asus MeMO Pad 7 ME176C Motherboard Replacement: 5 단계, 이미지 1/1
    • On the top right there is a small connector that connects to the motherboard.
    • This connector is a small wire. Be careful not to damage the wire.
    • Using the tweezer tool, carefully slide out the connector from the motherboard.
  6. Asus MeMO Pad 7 ME176C Motherboard Replacement: 6 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C Motherboard Replacement: 6 단계, 이미지 2/2
    • Next to the previous connector on the top right, there is another large connector.
    • Disconnect using a tweezer or a tool to easily slide the connector out.
  7. Asus MeMO Pad 7 ME176C Motherboard Replacement: 7 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C Motherboard Replacement: 7 단계, 이미지 2/2
    • Locate the screws around the motherboard.
    • Unscrew the screws using a Phillips Head Screwdriver PH000 around the motherboard.
    • Caution: Carefully place the screws in a safe place as you will need them to put back the motherboard.
  8. Asus MeMO Pad 7 ME176C Motherboard Replacement: 8 단계, 이미지 1/3 Asus MeMO Pad 7 ME176C Motherboard Replacement: 8 단계, 이미지 2/3 Asus MeMO Pad 7 ME176C Motherboard Replacement: 8 단계, 이미지 3/3
    • On the bottom right of the motherboard, there is a small opening.
    • Using a prying tool, gently pop up the motherboard.
결론
hmedina777
회원 가입일: 09/26/17
101 평판
안내서 1개 작성함
Cal Poly, Team S6-G3, Banghart Fall 2017 Cal Poly, Team S6-G3, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G3
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 14
전체 시간: 1,212
