주요 콘텐츠로 건너뛰기
Asus MeMO Pad 7 ME176C Side Buttons Replacement
필요한 것
  1. Asus MeMO Pad 7 ME176C Side Buttons Replacement, Side Buttons: 1 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C Side Buttons Replacement, Side Buttons: 1 단계, 이미지 2/2
    • Separate the front and back by prying in between the two with a plastic opening tool.
  2. Asus MeMO Pad 7 ME176C Side Buttons Replacement: 2 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C Side Buttons Replacement: 2 단계, 이미지 2/2
    • Now that the back has been removed, you can see the buttons marked in red.
    • Remove the buttons using the plastic opening tool.
  3. Asus MeMO Pad 7 ME176C Side Buttons Replacement: 3 단계, 이미지 1/1
    • Your buttons have been removed. You may now clean or replace them.
결론
Jeffrey Sorenson
회원 가입일: 09/26/17
110 평판
안내서 1개 작성함
Cal Poly, Team S6-G3, Banghart Fall 2017 Cal Poly, Team S6-G3, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G3
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 3
전체 시간: 212
