주요 콘텐츠로 건너뛰기
Asus MeMO Pad 7 ME176C Speaker Replacement
필요한 것
  1. Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: 1 단계, 이미지 1/2 Asus MeMO Pad 7 ME176C Speaker Replacement, Speakers: 1 단계, 이미지 2/2
    이 단계에 사용된 도구:
    iFixit Opening Tool
    $1.99
    구매
    • Make sure the device is turned off.
    • Carefully insert the opening tool on the edge of the phone.
    • Slowly lift up the panel from the device and repeat the process on the other side.
  2. Asus MeMO Pad 7 ME176C Speaker Replacement: 2 단계, 이미지 1/3 Asus MeMO Pad 7 ME176C Speaker Replacement: 2 단계, 이미지 2/3 Asus MeMO Pad 7 ME176C Speaker Replacement: 2 단계, 이미지 3/3
    • To disconnect the ZIF connectors. Place the metal spudger underneath the ZIF cable and gently pull it outward.
    • ZIF connectors are fragile, so work with caution.
  3. Asus MeMO Pad 7 ME176C Speaker Replacement: 3 단계, 이미지 1/3 Asus MeMO Pad 7 ME176C Speaker Replacement: 3 단계, 이미지 2/3 Asus MeMO Pad 7 ME176C Speaker Replacement: 3 단계, 이미지 3/3
    • The battery connector is located on the right-hand side of the device
    • To disconnect the battery connector. Use tweezers, and carefully lift up the wire.
    • Remove the battery.
  4. Asus MeMO Pad 7 ME176C Speaker Replacement: 4 단계, 이미지 1/1
    • Using a Philips Head Screwdriver PH000, locate the 2.6mm screws and gently unscrew them .
    • Place these screws somewhere you will remember.
    • Applying too much pressure onto the screen may cause it to break.
  5. Asus MeMO Pad 7 ME176C Speaker Replacement: 5 단계, 이미지 1/3 Asus MeMO Pad 7 ME176C Speaker Replacement: 5 단계, 이미지 2/3 Asus MeMO Pad 7 ME176C Speaker Replacement: 5 단계, 이미지 3/3
    • Using tweezers, disconnect the speaker cable connected to the motherboard.
    • Be sure not to damage other components on the motherboard.
    • After that remove the speaker system completely.
  6. Asus MeMO Pad 7 ME176C Speaker Replacement: 6 단계, 이미지 1/1
    • Now you can attach a new speaker!
결론
Maxime
회원 가입일: 09/26/17
101 평판
안내서 1개 작성함
Cal Poly, Team S6-G3, Banghart Fall 2017 Cal Poly, Team S6-G3, Banghart Fall 2017 회원
CPSU-BANGHART-F17S6G3
5 회원들
안내서 9개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 227
