주요 콘텐츠로 건너뛰기
Asus MeMO Pad 8 ME181C Battery Replacement
필요한 것
  1. Asus MeMO Pad 8 ME181C Battery Replacement, Rear Case: 1 단계, 이미지 2개 중 1개 Asus MeMO Pad 8 ME181C Battery Replacement, Rear Case: 1 단계, 이미지 2개 중 2개
    • Insert a plastic opening tool into the seam between the rear case and the screen.
    • Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
  2. Asus MeMO Pad 8 ME181C Battery Replacement, Battery: 2 단계, 이미지 3개 중 1개 Asus MeMO Pad 8 ME181C Battery Replacement, Battery: 2 단계, 이미지 3개 중 2개 Asus MeMO Pad 8 ME181C Battery Replacement, Battery: 2 단계, 이미지 3개 중 3개
    • Use the flat end of the nylon spudger to flip up the retaining flap of the Zero Insertion Force (ZIF) connector holding the orange motherboard ribbon cable in place.
  3. Asus MeMO Pad 8 ME181C Battery Replacement: 3 단계, 이미지 2개 중 1개 Asus MeMO Pad 8 ME181C Battery Replacement: 3 단계, 이미지 2개 중 2개
    • Use the flat end of the nylon spudger to flip up the retaining flap of the ZIF connector holding the black motherboard ribbon cable in place.
  4. Asus MeMO Pad 8 ME181C Battery Replacement: 4 단계, 이미지 2개 중 1개 Asus MeMO Pad 8 ME181C Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Use the pointed end of the nylon spudger to pop up the battery connector.
    • When reconnecting the battery cable after replacing the battery, press the battery connector with your finger until it clicks into place.
  5. Asus MeMO Pad 8 ME181C Battery Replacement: 5 단계, 이미지 2개 중 1개 Asus MeMO Pad 8 ME181C Battery Replacement: 5 단계, 이미지 2개 중 2개
    • Use the flat end of the nylon spudger to pry up the battery.
    • The battery is secured with adhesive. Some force is required to detach battery from the device.
    • If removing motherboard is necessary, it may be easier complete this step with the motherboard simultaneously later.
결론
다른 7명이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Amy Clarke
회원 가입일: 05/05/16
223 평판
안내서 2개를 작성함
iFixit, Team 1-1, Wacker Spring 2016 iFixit, Team 1-1, Wacker Spring 2016 회원
FIX-WACKER-S16S1G1
3 회원들
안내서 4개를 작성함
댓글 2개
Great instructions and easy disassembly/reassembly. Photos really helped!
Joe Martin - 답글
The time and difficulty for doing this and the me176cx should be the same.
P Schmied - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 8
전체 시간: 5,280
