주요 콘텐츠로 건너뛰기
Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement
필요한 것
  1. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement, Rear Case: 1 단계, 이미지 1/2 Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement, Rear Case: 1 단계, 이미지 2/2
    • Insert a plastic opening tool into the seam between the rear case and the screen.
    • Work the plastic opening tool around the perimeter of the device to completely remove the rear case.
  2. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement, Motherboard: 2 단계, 이미지 1/1
    • Working from top to bottom, you will remove all screws with a #000 Phillips head driver, (20) total.
    • (2) screws located in the top corners. NOTE: These screws will be in the speakers.
    • (4) screws located along the top of the battery, (3) along each side of the battery, and (3) along the bottom of the battery.
    • (1) screw in the middle of the motherboard on the side with the orange ribbon cable, (4) screws in the bottom of the motherboard .
  3. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: 3 단계, 이미지 1/1
    • Make sure that the battery is disconnected from the motherboard by unplugging the ribbon cables.
  4. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: 4 단계, 이미지 1/2 Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: 4 단계, 이미지 2/2
    • Before you remove the entire assembly, first unplug side buttons and cameras from the motherboard using tweezers.
    • The motherboard is easiest to remove simultaneously with the battery. Refer to Step 5 for more details.
  5. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: 5 단계, 이미지 1/2 Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement: 5 단계, 이미지 2/2
    • While the device is open, this is your opportunity to check and see if there is any other damage to the motherboard or other associated parts.
  6. Asus MeMO Pad 8 ME181C Rear Facing Camera Replacement, Rear Facing Camera: 6 단계, 이미지 1/1
    • Now carefully pry up the rear facing camera using a spudger.
    • Be careful when using the spudger as you do not want the tool to slip and damage other components of the tablet.
결론
Anthony Tillett
회원 가입일: 10/06/16
214 평판
안내서 2개 작성하였습니다
USF Tampa, Team 5-6, Lacy Fall 2016 USF Tampa, Team 5-6, Lacy Fall 2016 회원
USFT-LACY-F16S5G6
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 2
전체 시간: 210
