주요 콘텐츠로 건너뛰기
Asus MeMO Pad HD 7 Battery Replacement
필요한 것
  1. Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: 1 단계, 이미지 3개 중 1개 Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: 1 단계, 이미지 3개 중 2개 Asus MeMO Pad HD 7 Battery Replacement, Remove Rear Panel: 1 단계, 이미지 3개 중 3개
    • Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
    • Pull the back panel away from the device.
    • The volume buttons can fall out of the case. Pay attention so as not to lose them.
  2. Asus MeMO Pad HD 7 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Unlock the ZIF connectors on the data cables.
    • Raise the white locking tabs by lifting their upper edge - furthest from the battery - they hinge across the width of the connector.
    • Remove the cable from its slot by gently pulling downward on the tabs.
    • Check that the touchscreen cables are fully seated when reassembling or touchscreen may have unresponsive areas.
  3. Asus MeMO Pad HD 7 Battery Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the battery connector by following the wires that come from the top right of the battery. To disconnect the battery just lift up gently on the wires. Use a spudger or blue plastic opening tool to gently lift the wires if it is hard to get a grip.
  4. Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: 4 단계, 이미지 3개 중 1개 Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: 4 단계, 이미지 3개 중 2개 Asus MeMO Pad HD 7 Battery Replacement, Remove Battery: 4 단계, 이미지 3개 중 3개
    • Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
    • The battery has a soft casing, be careful not to tear the battery casing as chemicals could leak out.
결론
다른 14명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
Julien Daigle
회원 가입일: 01/20/15
1,235 평판
안내서 5개를 작성함
USF Tampa, Team 11-3, Blackwell Winter 2015 USF Tampa, Team 11-3, Blackwell Winter 2015 회원
USFT-BLACKWELL-W15S11G3
4 회원들
안내서 5개를 작성함
댓글 4개
Make sure you REMOVE the micro SD card prior to opening it! Otherwise you risk damaging the micro SD card port.
I just opened my tablet to change the battery, didn't realize this, and sure enough, broke it :(
Hope this helps you avoid that mistake.
dpietros - 답글
How did you fix the sd card port?
yanisstavrou - 답글
It is VERY important that you do not bend the battery during removal!! Even more advisable is discharging the battery completely prior to replacement.... I accidentally bent the old battery while attempting to remove it and the battery heated up, bulged and then exploded!
Eric - 답글
where can i buy battery for asus memopad here in naga city, cam sur,philippines?
chattyubante - 답글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 10
지난 30일: 22
전체 시간: 21,983
