소개
This guide is to show you how to replace the battery in an Asus MeMO Pad HD 7. This is a simple procedure that can be accomplished by anyone.
필요한 것
Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
Pull the back panel away from the device.
Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
I don't think you need to do this step (my motherboard came out and back in just fine, I just had to keep the battery cord out of the way, which is way easier than prying the whole thing out of there).
다른 14명이 해당 안내서를 완성하였습니다.
댓글 4개
How did you fix the sd card port?
where can i buy battery for asus memopad here in naga city, cam sur,philippines?
Important: Remove SD card first!
Ola Eldøy - 답글
