소개
This guide will step you through replacing the GPS Antenna on your Asus Tablet. This process is straight forward and should not be too difficult.
필요한 것
1 단계 Remove Rear Panel
주의: 1-4 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
Pull the back panel away from the device.
Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
Pry the GPS Antenna cable straight up using a spudger or similar prying tool. It will be the grey wire that runs up the right side of the device coming from the speaker housing up to the motherboard.
다른 2명이 해당 안내서를 완성하였습니다.
