소개
This guide will direct you in replacing the entire speaker assembly for the tablet. The guide will require a few simple steps and removing a few small screws form the device.
필요한 것
1 단계 Remove Rear Panel
주의: 1-4 단계들은 진행 중으로 표시된 안내서에서 제공되었습니다.
Carefully remove the back panel by using a plastic opening tool to remove the panel off the device.
Pull the back panel away from the device.
Using a spudger carefully pry the battery up. It is glued down so slight pressure may be needed.
Unscrew two Philip's #000 2 mm screws located on the left and right side of the speaker housing.
다른 3명이 해당 안내서를 완성하였습니다.
