주요 콘텐츠로 건너뛰기
Asus MeMo Pad 10 ME102A Back Panel Replacement
필요한 것
  1. Asus MeMo Pad 10 ME102A Back Panel Replacement, Back Panel: 1 단계, 이미지 1/1
    • Insert the blue plastic opening tool into the seam between the back panel and the chassis.
    • When removing the back panel, remember to keep the device face down on a flat surface in order to prevent dropping the device or anything inside of the device.
  2. Asus MeMo Pad 10 ME102A Back Panel Replacement: 2 단계, 이미지 1/1
    • Slide the plastic opener around the tablet. There will be spots of resistance. These should gently pop open as the tool slides through the seam.
  3. Asus MeMo Pad 10 ME102A Back Panel Replacement: 3 단계, 이미지 1/1
    • After all of the clips have been opened, the back panel should be free to remove by hand
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Andreas Niederer
회원 가입일: 09/15/16
426 평판
안내서 2개 작성하였습니다
USF Tampa, Team 11-3, Blackwell Fall 2016 USF Tampa, Team 11-3, Blackwell Fall 2016 회원
USFT-BLACKWELL-F16S11G3
4 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 10
전체 시간: 1,761
