소개
This guide will show you how to remove the battery of your Asus PadFone S. Some common tools are required for this replacement so make sure you have them before you start. The battery will be difficult to remove so make sure you follow the directions carefully.
필요한 것
Place your thumb in the charging port and pry the back cover off of the phone.
Remove all screws using the T5 Torx screwdriver
Lift the back panel off the phone.
다른 한 분이 해당 안내서를 완성하였습니다.
