소개
This guide will show you how to replace the logic board of your Asus PadFone S. Some common tools are required for this replacement so make sure you have them before you start. This guide requires some skill and you must be careful when following directions. This guide will help you with other replacement guides for the Asus PadFone S.
필요한 것
Place your thumb in the charging port and pry the back cover off of the phone.
Remove all screws using the T5 Torx screwdriver
Lift the back panel off the phone.
Disconnect all wires and bands from microphone, SIM card port and side bottons
Disconnect remaining band from the logic board
Lift the logic board out of the phone
다른 2명이 해당 안내서를 완성하였습니다.
