소개
This guide will show you how to remove the back camera of your Asus PadFone S. There are 3 moderate steps to this guide that require some precision and patience. This guide will make it easy to replace a broken or damaged back camera to get your phone working again. Some common tools are required for this replacement so make sure you have them before you start.
필요한 것
Place your thumb in the charging port and pry the back cover off of the phone.
Separate cover all the way around the sides of the phone.
Remove all the screws on the back panel using a T5 Torx screwdriver.
Lift the back panel off to reveal the logic board and battery.
다른 한 분이 해당 안내서를 완성하였습니다.
