주요 콘텐츠로 건너뛰기
Asus Padfone 2 A68 Sub Cables Replacement
필요한 것
  1. Asus Padfone 2 A68 Sub Cables Replacement, Power Down Device: 1 단계, 이미지 1/1
    • Hold down the power button.
  2. Asus Padfone 2 A68 Sub Cables Replacement, Remove Back Plate: 2 단계, 이미지 1/3 Asus Padfone 2 A68 Sub Cables Replacement, Remove Back Plate: 2 단계, 이미지 2/3 Asus Padfone 2 A68 Sub Cables Replacement, Remove Back Plate: 2 단계, 이미지 3/3
    • Use plastic opening tools to pry off the cover of the phone.
  3. Asus Padfone 2 A68 Sub Cables Replacement, Battery Removal: 3 단계, 이미지 1/3 Asus Padfone 2 A68 Sub Cables Replacement, Battery Removal: 3 단계, 이미지 2/3 Asus Padfone 2 A68 Sub Cables Replacement, Battery Removal: 3 단계, 이미지 3/3
    • Remove the warning sticker that covers the battery plug and connecting cord.
    • Look for the widest gap on either side of the battery. Using the plastic opening tool carefully lift battery out.
    • The battery is held down with adhesive. Be careful not to damage battery or connecting cord.
    • Disconnect battery connecting cord using tweezers.
  4. Asus Padfone 2 A68 Sub Cables Replacement, Remove Internal Back Plate: 4 단계, 이미지 1/2 Asus Padfone 2 A68 Sub Cables Replacement, Remove Internal Back Plate: 4 단계, 이미지 2/2
    • Use T5 Torx screwdriver to remove 14 screws from internal back plate.
    • Use of magnetic pad will help with keeping track of screws.
    • Once screws are out, remove the plate.
  5. Asus Padfone 2 A68 Sub Cables Replacement, Removal of A68 Sub Cables: 5 단계, 이미지 1/1
    • Use tweezers to unplug the sub cables from the circuit board and housing.
  6. Asus Padfone 2 A68 Sub Cables Replacement, Replacing the A68 Sub Cables: 6 단계, 이미지 1/2 Asus Padfone 2 A68 Sub Cables Replacement, Replacing the A68 Sub Cables: 6 단계, 이미지 2/2
    • Plug in new sub cables to the circuit board and housing.
결론
Erica
회원 가입일: 09/25/14
467 평판
안내서 2개 작성하였습니다
USF Tampa, Team 5-4, Mcgee Fall 2014 USF Tampa, Team 5-4, Mcgee Fall 2014 회원
USFT-MCGEE-F14S5G4
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
Boas. Onde posso comprar este cabo?
rsebastiao - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 1,215
