주요 콘텐츠로 건너뛰기
Asus Padfone X Mini Docking Port Replacement
필요한 것
  1. Asus Padfone X Mini Docking Port Replacement, Docking Port: 1 단계, 이미지 1/1
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
  2. Asus Padfone X Mini Docking Port Replacement: 2 단계, 이미지 1/1
    • Take the battery out of the phone.
  3. Asus Padfone X Mini Docking Port Replacement: 3 단계, 이미지 1/2 Asus Padfone X Mini Docking Port Replacement: 3 단계, 이미지 2/2
    • Remove the 10 screws around the perimeter of the phone.
    • Remove the cover.
  4. Asus Padfone X Mini Docking Port Replacement: 4 단계, 이미지 1/1
    • Use tweezers to remove the black strip on the left side of the motherboard.
    • The motherboard is the green board on the side with the screen.
    • Be careful not to rip this black strip out of the phone since you will need to reconnect it later. You only need to disconnect it from the mother board.
  5. Asus Padfone X Mini Docking Port Replacement: 5 단계, 이미지 1/1
    • Remove the gold flap on the left side of the motherboard.
  6. Asus Padfone X Mini Docking Port Replacement: 6 단계, 이미지 1/1
    • Remove the motherboard and replace it.
    • The docking port is connected to your motherboard so you have to get the whole thing replaced if it isn't working.
결론
Nicolette Carr
회원 가입일: 09/18/18
383 평판
안내서 2개 작성하였습니다
University of North Texas, Team S4-G2, Raign Fall 2018 University of North Texas, Team S4-G2, Raign Fall 2018 회원
UNT-RAIGN-F18S4G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 0
전체 시간: 183
