주요 콘텐츠로 건너뛰기
Asus Padfone X Mini Screen Replacement
필요한 것
  1. Asus Padfone X Mini Screen Replacement, Speaker: 1 단계, 이미지 1/1
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • This is not the cover with the speaker attached.
  2. Asus Padfone X Mini Screen Replacement: 2 단계, 이미지 1/1
    • Lift the battery out from the top of the device.
  3. Asus Padfone X Mini Screen Replacement: 3 단계, 이미지 1/1
    • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Remove the cover.
  4. Asus Padfone X Mini Screen Replacement: 4 단계, 이미지 1/1
    • Turn the cover over.
    • The speaker is attached to the inside of the cover and to the right of the camera hole.
  5. Asus Padfone X Mini Screen Replacement: 5 단계, 이미지 1/1
    • Remove speaker with standard tweezers to minimize damage, and replace.
  6. Asus Padfone X Mini Screen Replacement, Screen: 6 단계, 이미지 1/1
    • Detach the black connector on the left hand side of the motherboard.
    • Don't completely remove the black connector.
  7. Asus Padfone X Mini Screen Replacement: 7 단계, 이미지 1/1
    • Disconnect silver connector from the motherboard. It is located on the left hand side above the black connector.
  8. Asus Padfone X Mini Screen Replacement: 8 단계, 이미지 1/2 Asus Padfone X Mini Screen Replacement: 8 단계, 이미지 2/2
    • Remove motherboard and replace screen.
결론
Benjamin Trigg
회원 가입일: 09/18/18
97 평판
안내서 1개 작성함
University of North Texas, Team S4-G2, Raign Fall 2018 University of North Texas, Team S4-G2, Raign Fall 2018 회원
UNT-RAIGN-F18S4G2
4 회원들
안내서 8개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 3
전체 시간: 251
