주요 콘텐츠로 건너뛰기
  1. With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • With the phone facing down, look at the bottom right side corner and there should be a groove. Use a plastic opening tool and lift up to remove outside cover.
    • This is not the cover with the speaker attached.
  2. Lift the battery out from the top of the device.
    • Lift the battery out from the top of the device.
  3. PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
    PC 노트북 배터리
    큰 전력 향상을 위한 손쉬운 수리.
    지금 장보기
  4. Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Around the perimeter, there should be 10 2 mm T5 Torx screws. Take them out.
    • Remove the cover.
  5. Turn the cover over.
    • Turn the cover over.
    • The speaker is attached to the inside of the cover and to the right of the camera hole.
  6. Remove speaker with standard tweezers to minimize damage, and replace.
    • Remove speaker with standard tweezers to minimize damage, and replace.
결론
Nicolette Carr
회원 가입일: 2018년 09월 18일
368 평판
안내서 2개 작성하였습니다
University of North Texas, Team S4-G2, Raign Fall 2018 University of North Texas, Team S4-G2, Raign Fall 2018 회원
UNT-RAIGN-F18S4G2
4 회원들
안내서 4개 작성하였습니다
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 0
지난 30일: 1
전체 시간: 48
