주요 콘텐츠로 건너뛰기
Asus Q200E-CT144H Back Cover Replacement
필요한 것
  1. Asus Q200E-CT144H Back Cover Replacement, Back Cover: 1 단계, 이미지 1/1
    • To start, turn off the laptop and disconnect the power cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Flip the laptop over so the back panel is visible.
  2. Asus Q200E-CT144H Back Cover Replacement: 2 단계, 이미지 1/1
    • Remove the 9 screws holding the cover in place by taking a Phillips #00 Screwdriver and turning it counterclockwise.
  3. Asus Q200E-CT144H Back Cover Replacement: 3 단계, 이미지 1/2 Asus Q200E-CT144H Back Cover Replacement: 3 단계, 이미지 2/2
    • Use an iFixit opening tool to lift the back cover and remove it from the laptop.
결론
Kirsti Wattles
회원 가입일: 09/16/19
689 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 4
전체 시간: 144
