주요 콘텐츠로 건너뛰기
Asus Q200E-CT144H Wi-Fi Card Replacement
필요한 것
  1. Asus Q200E-CT144H Wi-Fi Card Replacement, Back Cover: 1 단계, 이미지 1/1
    • To start, turn off the laptop and disconnect the power cable.
    • If the computer is on or plugged in, it could cause electric shock.
    • Flip the laptop over so the back panel is visible.
  2. Asus Q200E-CT144H Wi-Fi Card Replacement: 2 단계, 이미지 1/1
    • Remove the 9 screws holding the cover in place by taking a Phillips #00 Screwdriver and turning it counterclockwise.
  3. Asus Q200E-CT144H Wi-Fi Card Replacement: 3 단계, 이미지 1/2 Asus Q200E-CT144H Wi-Fi Card Replacement: 3 단계, 이미지 2/2
    • Use an iFixit opening tool to lift the back cover and remove it from the laptop.
  4. Asus Q200E-CT144H Wi-Fi Card Replacement, Battery: 4 단계, 이미지 1/2 Asus Q200E-CT144H Wi-Fi Card Replacement, Battery: 4 단계, 이미지 2/2
    이 단계에 사용된 도구:
    구매
    • Remove the battery connector by using tweezers to lift up on it.
  5. Asus Q200E-CT144H Wi-Fi Card Replacement: 5 단계, 이미지 1/2 Asus Q200E-CT144H Wi-Fi Card Replacement: 5 단계, 이미지 2/2
    • Remove the nine Phillips #00 screws that hold the battery in place.
    • There is one 9.2mm screw, four 4.7mm screws, and four 5.7mm screws.
  6. Asus Q200E-CT144H Wi-Fi Card Replacement: 6 단계, 이미지 1/2 Asus Q200E-CT144H Wi-Fi Card Replacement: 6 단계, 이미지 2/2
    • Remove the battery from the battery bay.
  7. Asus Q200E-CT144H Wi-Fi Card Replacement, Wi-Fi Card: 7 단계, 이미지 1/1
    이 단계에 사용된 도구:
    구매
    • Use tweezers or your fingers to disconnect the Wi-Fi card's power connector.
  8. Asus Q200E-CT144H Wi-Fi Card Replacement: 8 단계, 이미지 1/1
    • Unscrew the single 4.7mm screw with a Phillips #00 screwdriver.
  9. Asus Q200E-CT144H Wi-Fi Card Replacement: 9 단계, 이미지 1/1
    • Remove the card from its bay.
결론
Kirsti Wattles
회원 가입일: 09/16/19
689 평판
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 4
전체 시간: 130
