주요 콘텐츠로 건너뛰기
Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement
필요한 것
  1. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement, Fan and Heat Sink: 1 단계, 이미지 1/2 Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement, Fan and Heat Sink: 1 단계, 이미지 2/2
    • Unscrew the ten 10mm Phillips #0 screws.
    • Use the plastic opening tool along the side of the laptop to pry open.
  2. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: 2 단계, 이미지 1/2 Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: 2 단계, 이미지 2/2
    • Remove the seven 4mm Phillips #0 screws.
    • Gently pull the connector.
  3. Asus Q302UA-BHI5T20 Fan and Heat Sink Replacement: 3 단계, 이미지 1/1
    • Lift the heat sink and fan assembly, and you are done!
    • There maybe a little resistance to being pulled up since the heat sink is attached to the CPU with thermal paste
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Arthur Sperotto
회원 가입일: 11/08/18
118 평판
안내서 1개 작성함
IUPUI, Team S1-G2, Hovde Fall 2018 IUPUI, Team S1-G2, Hovde Fall 2018 회원
IUPUI-HOVDE-F18S1G2
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 12
전체 시간: 133
