주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Q304UA Hard Drive Replacement
필요한 것
  1. Asus Q304UA Hard Drive Replacement, Remove Bottom Cover: 1 단계, 이미지 1개 중 1개
    • Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
    • Six 9.6 mm screws
    • Four 4.6 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  2. Asus Q304UA Hard Drive Replacement: 2 단계, 이미지 3개 중 1개 Asus Q304UA Hard Drive Replacement: 2 단계, 이미지 3개 중 2개 Asus Q304UA Hard Drive Replacement: 2 단계, 이미지 3개 중 3개
    • Use a plastic pry tool to get in-between the bottom cover and the lower case assembly.
    • Be careful not separate the cover too violently or you will risk breaking the plastic clips that are on the bottom cover.
  3. Asus Q304UA Hard Drive Replacement, Disconnect the battery: 3 단계, 이미지 3개 중 1개 Asus Q304UA Hard Drive Replacement, Disconnect the battery: 3 단계, 이미지 3개 중 2개 Asus Q304UA Hard Drive Replacement, Disconnect the battery: 3 단계, 이미지 3개 중 3개
    • Push metal bracket away from battery connector.
    • Use a spudger to push the battery connection straight up.
    • If you pry too hard, or attempt to disconnect the battery with the metal bracket still in place, you risk pulling the connector off of the motherboard.
    • Make sure the computer is powered off before removing the battery.
  4. Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: 4 단계, 이미지 3개 중 1개 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: 4 단계, 이미지 3개 중 2개 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: 4 단계, 이미지 3개 중 3개
    • Disconnect the Wifi/Bluetooth RF cables from the wireless card.
    • Pull the RF cables by the metal connector, not by the rubber shielding. This avoids damaging the connector and the cable.
  5. Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: 5 단계, 이미지 2개 중 1개 Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: 5 단계, 이미지 2개 중 2개
    • Pull straight up to disconnect the SATA combo cable from the motherboard.
  6. Asus Q304UA Hard Drive Replacement: 6 단계, 이미지 1개 중 1개
    • Remove three Phillips #0 that secure the hard drive bracket to the chassis, of the following lengths:
    • Two 2.3 mm screws
    • One 5.6 mm screw
  7. Asus Q304UA Hard Drive Replacement: 7 단계, 이미지 3개 중 1개 Asus Q304UA Hard Drive Replacement: 7 단계, 이미지 3개 중 2개 Asus Q304UA Hard Drive Replacement: 7 단계, 이미지 3개 중 3개
    • Tilt the drive up slightly by the connector
    • Remove the SATA combo connector
  8. Asus Q304UA Hard Drive Replacement: 8 단계, 이미지 2개 중 1개 Asus Q304UA Hard Drive Replacement: 8 단계, 이미지 2개 중 2개
    • De-route the SATA and RF cables from the side of the drive bay.
  9. Asus Q304UA Hard Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Insert wisdom here.
  10. Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: 10 단계, 이미지 2개 중 1개 Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: 10 단계, 이미지 2개 중 2개
    • Remove the four Phillips #0 screws that secure the hard drive to the hard drive bracket.
    • Four 3.7 mm screws
  11. Asus Q304UA Hard Drive Replacement: 11 단계, 이미지 3개 중 1개 Asus Q304UA Hard Drive Replacement: 11 단계, 이미지 3개 중 2개 Asus Q304UA Hard Drive Replacement: 11 단계, 이미지 3개 중 3개
    • Peal back thermal cover.
    • Be careful not to tear the cover on the side of the drive as you peel it off.
  12. Asus Q304UA Hard Drive Replacement: 12 단계, 이미지 1개 중 1개
    • Remove drive from hard drive bracket.
결론
다른 3명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
iHelpU.Tech
회원 가입일: 08/02/17
4,050 평판
안내서 5개를 작성함
iHelpU.tech iHelpU.tech 회원
Business
2 회원들
안내서 17개를 작성함
2가이드 댓글
This should be rated moderate. Easy is sliding out a drive bay on a old Dell laptop from 15 years ago. :)
Michael Maxson - 답글 공유
I just wanted to disconnect the battery to reset the BIOS. Old machine. But when I did step 3 (Push metal bracket away from battery connector) the metal bracket touched something on the board and created a small spark. The machine would no longer power up. I must have fried the power supply. If I had to do it over, I would have put tape on the board near the metal bracket so it couldn't touch anything. Also, trying to get that bracket back on was super difficult.
yakerjohn - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 13
지난 30일: 56
전체 시간: 5,725
