주요 콘텐츠로 건너뛰기
Asus Q304UA Hard Drive Replacement
필요한 것
  1. Asus Q304UA Hard Drive Replacement, Remove Bottom Cover: 1 단계, 이미지 1/1
    • Remove ten Phillips #0 screws that secure the plastic bottom cover to the chassis.
    • Six 9.6 mm screws
    • Four 4.6 mm screws
    • Throughout this guide, keep careful track of your screws so that each one goes back where it came from during reassembly. Installing a screw in the wrong place can cause permanent damage.
  2. Asus Q304UA Hard Drive Replacement: 2 단계, 이미지 1/3 Asus Q304UA Hard Drive Replacement: 2 단계, 이미지 2/3 Asus Q304UA Hard Drive Replacement: 2 단계, 이미지 3/3
    • Use a plastic pry tool to get in-between the bottom cover and the lower case assembly.
    • Be careful not separate the cover too violently or you will risk breaking the plastic clips that are on the bottom cover.
  3. Asus Q304UA Hard Drive Replacement, Disconnect the battery: 3 단계, 이미지 1/3 Asus Q304UA Hard Drive Replacement, Disconnect the battery: 3 단계, 이미지 2/3 Asus Q304UA Hard Drive Replacement, Disconnect the battery: 3 단계, 이미지 3/3
    • Push metal bracket away from battery connector.
    • Use a spudger to push the battery connection straight up.
    • If you pry too hard, or attempt to disconnect the battery with the metal bracket still in place, you risk pulling the connector off of the motherboard.
    • Make sure the computer is powered off before removing the battery.
  4. Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: 4 단계, 이미지 1/3 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: 4 단계, 이미지 2/3 Asus Q304UA Hard Drive Replacement, Disconnect RF Cables: 4 단계, 이미지 3/3
    • Disconnect the Wifi/Bluetooth RF cables from the wireless card.
    • Pull the RF cables by the metal connector, not by the rubber shielding. This avoids damaging the connector and the cable.
  5. Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: 5 단계, 이미지 1/2 Asus Q304UA Hard Drive Replacement, Hard Drive Assembly: 5 단계, 이미지 2/2
    • Pull straight up to disconnect the SATA combo cable from the motherboard.
  6. Asus Q304UA Hard Drive Replacement: 6 단계, 이미지 1/1
    • Remove three Phillips #0 that secure the hard drive bracket to the chassis, of the following lengths:
    • Two 2.3 mm screws
    • One 5.6 mm screw
  7. Asus Q304UA Hard Drive Replacement: 7 단계, 이미지 1/3 Asus Q304UA Hard Drive Replacement: 7 단계, 이미지 2/3 Asus Q304UA Hard Drive Replacement: 7 단계, 이미지 3/3
    • Tilt the drive up slightly by the connector
    • Remove the SATA combo connector
  8. Asus Q304UA Hard Drive Replacement: 8 단계, 이미지 1/2 Asus Q304UA Hard Drive Replacement: 8 단계, 이미지 2/2
    • De-route the SATA and RF cables from the side of the drive bay.
  9. Asus Q304UA Hard Drive Replacement: 9 단계, 이미지 1/1
    • Insert wisdom here.
  10. Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: 10 단계, 이미지 1/2 Asus Q304UA Hard Drive Replacement, Hard Drive Bracket Assembly: 10 단계, 이미지 2/2
    • Remove the four Phillips #0 screws that secure the hard drive to the hard drive bracket.
    • Four 3.7 mm screws
  11. Asus Q304UA Hard Drive Replacement: 11 단계, 이미지 1/3 Asus Q304UA Hard Drive Replacement: 11 단계, 이미지 2/3 Asus Q304UA Hard Drive Replacement: 11 단계, 이미지 3/3
    • Peal back thermal cover.
    • Be careful not to tear the cover on the side of the drive as you peel it off.
  12. Asus Q304UA Hard Drive Replacement: 12 단계, 이미지 1/1
    • Remove drive from hard drive bracket.
결론
다른 3명이 해당 안내서를 완성하였습니다.
iHelpU.Tech
회원 가입일: 08/02/17
3,585 평판
안내서 5개 작성하였습니다
iHelpU.tech iHelpU.tech 회원
Business
2 회원들
안내서 16개 작성하였습니다
댓글 한 개
This should be rated moderate. Easy is sliding out a drive bay on a old Dell laptop from 15 years ago. :)
Michael Maxson - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 18
전체 시간: 5,134
