주요 콘텐츠로 건너뛰기
Asus Q325U Motherboard Replacement
필요한 것
  1. Asus Q325U Motherboard Replacement, Back Panel: 1 단계, 이미지 1/3 Asus Q325U Motherboard Replacement, Back Panel: 1 단계, 이미지 2/3 Asus Q325U Motherboard Replacement, Back Panel: 1 단계, 이미지 3/3
    • Remove the ten 5mm screws using a T5 Torx screwdriver.
  2. Asus Q325U Motherboard Replacement: 2 단계, 이미지 1/3 Asus Q325U Motherboard Replacement: 2 단계, 이미지 2/3 Asus Q325U Motherboard Replacement: 2 단계, 이미지 3/3
    • Lift the back panel upward using the suction tool.
  3. Asus Q325U Motherboard Replacement, SSD: 3 단계, 이미지 1/2 Asus Q325U Motherboard Replacement, SSD: 3 단계, 이미지 2/2
    • Remove one 2mm screw on top of the SSD using a Phillips #1 screwdriver.
  4. Asus Q325U Motherboard Replacement: 4 단계, 이미지 1/2 Asus Q325U Motherboard Replacement: 4 단계, 이미지 2/2
    • Carefully slide and lift the SSD to remove it.
  5. Asus Q325U Motherboard Replacement, Battery: 5 단계, 이미지 1/2 Asus Q325U Motherboard Replacement, Battery: 5 단계, 이미지 2/2
    • Remove the seven 5mm screws around the battery using a Phillips #00 screwdriver.
  6. Asus Q325U Motherboard Replacement: 6 단계, 이미지 1/2 Asus Q325U Motherboard Replacement: 6 단계, 이미지 2/2
    • Using a Phillips #000 screwdriver, remove the two 3mm screws on top of the orange battery connector.
  7. Asus Q325U Motherboard Replacement: 7 단계, 이미지 1/2 Asus Q325U Motherboard Replacement: 7 단계, 이미지 2/2
    • Lift the battery out from the laptop.
  8. Asus Q325U Motherboard Replacement, Copper Plate: 8 단계, 이미지 1/2 Asus Q325U Motherboard Replacement, Copper Plate: 8 단계, 이미지 2/2
    • Remove the six 3mm screws using a Phillips #00.
  9. Asus Q325U Motherboard Replacement: 9 단계, 이미지 1/2 Asus Q325U Motherboard Replacement: 9 단계, 이미지 2/2
    • Use the plastic opening tool to lift up the edge. Pull upward on the edge.
  10. Asus Q325U Motherboard Replacement: 10 단계, 이미지 1/2 Asus Q325U Motherboard Replacement: 10 단계, 이미지 2/2
    • On the other side of the plate, remove the tape.
  11. Asus Q325U Motherboard Replacement, CPU Fan: 11 단계, 이미지 1/2 Asus Q325U Motherboard Replacement, CPU Fan: 11 단계, 이미지 2/2
    • Remove the three 3.7 mm screws using a Phillips #00 screwdriver.
  12. Asus Q325U Motherboard Replacement: 12 단계, 이미지 1/1
    • Detach the black wire and plug shown using a tweezer.
  13. Asus Q325U Motherboard Replacement: 13 단계, 이미지 1/1
    • Grab CPU fan by its edge and gently pull upwards to remove.
  14. Asus Q325U Motherboard Replacement, Motherboard: 14 단계, 이미지 1/2 Asus Q325U Motherboard Replacement, Motherboard: 14 단계, 이미지 2/2
    • Remove the first connection wire by pulling the small back loop with the Halberd Spudger.
  15. Asus Q325U Motherboard Replacement: 15 단계, 이미지 1/3 Asus Q325U Motherboard Replacement: 15 단계, 이미지 2/3 Asus Q325U Motherboard Replacement: 15 단계, 이미지 3/3
    이 단계에 사용된 도구:
    구매
    • Lift the small black tab of the orange connector with your fingers or a plastic opening tool.
    • Remove the orange connector by pulling with tweezers.
  16. Asus Q325U Motherboard Replacement: 16 단계, 이미지 1/3 Asus Q325U Motherboard Replacement: 16 단계, 이미지 2/3 Asus Q325U Motherboard Replacement: 16 단계, 이미지 3/3
    • Lift the small black tab on the white plastic piece of the touch pad connector with a spudger.
    • Remove the touch pad connector by pulling with tweezers.
  17. Asus Q325U Motherboard Replacement: 17 단계, 이미지 1/3 Asus Q325U Motherboard Replacement: 17 단계, 이미지 2/3 Asus Q325U Motherboard Replacement: 17 단계, 이미지 3/3
    • Lift the black tab on the long white plastic piece of the thick blue band.
    • Remove the thick blue band by pulling.
  18. Asus Q325U Motherboard Replacement: 18 단계, 이미지 1/3 Asus Q325U Motherboard Replacement: 18 단계, 이미지 2/3 Asus Q325U Motherboard Replacement: 18 단계, 이미지 3/3
    • Remove the two Phillips #000 screws on the metal connector above the thick orange band.
    • Lift up the thick orange band.
  19. Asus Q325U Motherboard Replacement: 19 단계, 이미지 1/3 Asus Q325U Motherboard Replacement: 19 단계, 이미지 2/3 Asus Q325U Motherboard Replacement: 19 단계, 이미지 3/3
    • Gently lift up the two smallest connectors using your fingers or a plastic opening tool.
  20. Asus Q325U Motherboard Replacement: 20 단계, 이미지 1/2 Asus Q325U Motherboard Replacement: 20 단계, 이미지 2/2
    • Lift up the black hinge of the connector using a plastic opening tool.
    • Remove the connector using a tweezer.
  21. Asus Q325U Motherboard Replacement: 21 단계, 이미지 1/3 Asus Q325U Motherboard Replacement: 21 단계, 이미지 2/3 Asus Q325U Motherboard Replacement: 21 단계, 이미지 3/3
    • Pull up the tap of the biggest connector using your fingers.
    • Lift the gold hinge using a plastic opening tool.
    • Lift the connector up with your fingers to remove.
  22. Asus Q325U Motherboard Replacement: 22 단계, 이미지 1/2 Asus Q325U Motherboard Replacement: 22 단계, 이미지 2/2
    • Remove the four 4.8 mm screws using a Phillips #00 screwdriver.
  23. Asus Q325U Motherboard Replacement: 23 단계, 이미지 1/2 Asus Q325U Motherboard Replacement: 23 단계, 이미지 2/2
    • Slightly open up the laptop. This will lift up the hinge at the corner and free the motherboard.
  24. Asus Q325U Motherboard Replacement: 24 단계, 이미지 1/2 Asus Q325U Motherboard Replacement: 24 단계, 이미지 2/2
    • Pull the motherboard away from the corner to remove.
결론
Miriam Miller
회원 가입일: 01/24/19
678 평판
안내서 4개 작성하였습니다
Cal Poly, Team 2-1, Johann Winter 2023 Cal Poly, Team 2-1, Johann Winter 2023 회원
CPSU-JOHANN-W23S2G1
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Can you help me identify which of those is the webcam conector? I hava a faulty webcam and my guess is that it is a physical conection problem.
pgmolin - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 14
전체 시간: 849
