주요 콘텐츠로 건너뛰기
Asus Q500A Battery Replacement
  1. Asus Q500A Battery Replacement, Battery: 1 단계, 이미지 1/1
    • Flip device onto backside.
  2. Asus Q500A Battery Replacement: 2 단계, 이미지 1/1
    • Locate the two sliding locks.
    • Slide the sliding lock 1 to the right to unlock it .
    • There should be a red marker to indicate that it is unlocked. This lock will stay unlocked until slid back into the locked position.
  3. Asus Q500A Battery Replacement: 3 단계, 이미지 1/1
    • Slide the sliding lock 2 to the left to unlock it.
    • There will not be any indicator that it is unlocked. This lock will relock if you do not continue to push it to the left.
  4. Asus Q500A Battery Replacement: 4 단계, 이미지 1/1
    • While the first and second lock are unlocked, slide the battery out to remove it.
    • When reinserting the replacement battery, make sure to slide sliding lock 1 back into the locked position. Otherwise the battery may come loose.
결론
cameron
회원 가입일: 02/15/17
319 평판
안내서 3개 작성하였습니다
USF Tampa, Team 12-5, Eyestone Spring 2017 USF Tampa, Team 12-5, Eyestone Spring 2017 회원
USFT-EYESTONE-S17S12G5
3 회원들
안내서 3개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 3
7일 전: 3
30일 전: 5
전체 시간: 501
