주요 콘텐츠로 건너뛰기
Asus Q501LA-BBI6T03 Hard Drive Replacement
필요한 것
  1. Asus Q501LA-BBI6T03 Hard Drive Replacement, Back Panel: 1 단계, 이미지 1/1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Hard Drive Replacement: 2 단계, 이미지 1/1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Hard Drive Replacement: 3 단계, 이미지 1/2 Asus Q501LA-BBI6T03 Hard Drive Replacement: 3 단계, 이미지 2/2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Hard Drive Replacement, Hard Drive: 4 단계, 이미지 1/1
    • Remove the four 3mm Phillips #0 screws shown.
  5. Asus Q501LA-BBI6T03 Hard Drive Replacement: 5 단계, 이미지 1/1
    • Take hard drive out of the port by sliding the component to the left.
    • There is only one way it comes out of the connector. If it seems too hard to push out you are probably going the wrong way.
  6. Asus Q501LA-BBI6T03 Hard Drive Replacement: 6 단계, 이미지 1/1
    • Once the hard drive has been removed from the connector, use your thumb to get under and lift the hard drive out.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Aodhan Arias
회원 가입일: 01/25/17
288 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-1, Banghart Winter 2017 Cal Poly, Team 8-1, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 1
30일 전: 12
전체 시간: 2,688
