주요 콘텐츠로 건너뛰기
Asus Q501LA-BBI6T03 Heat Sink Disassembly
필요한 것
  1. Asus Q501LA-BBI6T03 Heat Sink Disassembly, Back Panel: 1 단계, 이미지 1/1
    • Ensure the laptop is powered down before continuing.
    • Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
  2. Asus Q501LA-BBI6T03 Heat Sink Disassembly: 2 단계, 이미지 1/1
    • Use the spudger to pry open the rear cover at either hinge.
  3. Asus Q501LA-BBI6T03 Heat Sink Disassembly: 3 단계, 이미지 1/2 Asus Q501LA-BBI6T03 Heat Sink Disassembly: 3 단계, 이미지 2/2
    • Grab the cover with your fingers and gently lift it away from the board.
    • Be careful not to break any tabs on the cover when lifting it off.
  4. Asus Q501LA-BBI6T03 Heat Sink Disassembly, Heat Sink/Fan Assembly: 4 단계, 이미지 1/1
    • Remove the seven 4mm Phillips #0 screws holding the heat sink/fan assembly onto the motherboard.
  5. Asus Q501LA-BBI6T03 Heat Sink Disassembly: 5 단계, 이미지 1/1
    • Using the spudger, unplug the fan from the motherboard connection by carefully pushing on both sides of the connector.
  6. Asus Q501LA-BBI6T03 Heat Sink Disassembly: 6 단계, 이미지 1/1
    • Lift up on the fan, copper heat pipe and heat sink assembly, and remove from motherboard.
    • Be careful when removing the heat sink unit from the CPU, as there will be thermal paste residue that will have be to cleaned and new thermal paste applied.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Kyle Nagao
회원 가입일: 01/25/17
366 평판
안내서 2개 작성하였습니다
Cal Poly, Team 8-1, Banghart Winter 2017 Cal Poly, Team 8-1, Banghart Winter 2017 회원
CPSU-BANGHART-W17S8G1
3 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 13
전체 시간: 780
