소개
If your laptop is running hot, you may decide to either replace or clean out your fan unit, and replace the thermal compound with better quality.
필요한 것
Use a Phillips #0 screwdriver to remove the ten 3mm Phillips head screws on the base of the laptop.
Remove the seven 4mm Phillips #0 screws holding the heat sink/fan assembly onto the motherboard.
거의 끝나갑니다!
결론
다른 한 분이 해당 안내서를 완성하였습니다.
