소개
This guide teaches you how to replace the hard drive in an Asus Q502LA.
필요한 것
Remove the ten rather long Philips screws from the bottom cover.
Use a spudger to pry the bottom cover off.
Remove the four screws securing the hard drive caddy.
Pull on the tab to remove the caddy from the laptop.
Unscrew the four screws holding the hard drive to the caddy. You're done!
거의 끝나갑니다!
결론
다른 2명이 해당 안내서를 완성하였습니다.
