주요 콘텐츠로 건너뛰기
Asus Q502LA-BSI5T14 Battery Replacement
필요한 것
  1. Asus Q502LA-BSI5T14 Battery Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Battery Replacement: 2 단계, 이미지 1개 중 1개
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Battery Replacement: 3 단계, 이미지 2개 중 1개 Asus Q502LA-BSI5T14 Battery Replacement: 3 단계, 이미지 2개 중 2개
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Battery Replacement: 4 단계, 이미지 2개 중 1개 Asus Q502LA-BSI5T14 Battery Replacement: 4 단계, 이미지 2개 중 2개
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Mary Kounelas
회원 가입일: 09/25/17
742 평판
안내서 5개를 작성함
USF Tampa, Team S4-G1, Eyestone Fall 2017 USF Tampa, Team S4-G1, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G1
4 회원들
안내서 5개를 작성함
댓글 2개
Got as far as the removal from wires. How is that done. A total newbie. I just lifted the battery slightly. Would this help with the static or do I totally need to remove the battery? Laptop shows battery is almost fully charged. There is not a green light.
Berta Stoffel - 답글
Mine has no green light at first but after battery reaches full state it is there. However annoyingly flickers (screen and all) between charge state and discharging at full. Luckily seems to work fine across the whole range of charging. Can't believe this Q502LA is still holding on after 8 years :) Wondering if there is any battery drive/update?
jsbenami - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 16
전체 시간: 4,595
