주요 콘텐츠로 건너뛰기
Asus Q502LA-BSI5T14 Fan Replacement
필요한 것
  1. Asus Q502LA-BSI5T14 Fan Replacement, Fan: 1 단계, 이미지 1/1
    • Make sure your device is powered off before you begin.
    • Flip the laptop over and remove the ten 11 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Fan Replacement: 2 단계, 이미지 1/1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Fan Replacement: 3 단계, 이미지 1/1
    • Remove the eight 5 mm Phillips #1 screws securing the fan and copper piece to the motherboard.
    • Remove the wires by gently pulling them out.
  4. Asus Q502LA-BSI5T14 Fan Replacement: 4 단계, 이미지 1/1
    • Gently lift the fan up and away from the laptop.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Mary Kounelas
회원 가입일: 09/25/17
715 평판
안내서 5개 작성하였습니다
USF Tampa, Team S4-G1, Eyestone Fall 2017 USF Tampa, Team S4-G1, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 10
전체 시간: 376
