주요 콘텐츠로 건너뛰기
Asus Q502LA-BSI5T14 Motherboard Replacement
필요한 것
  1. Asus Q502LA-BSI5T14 Motherboard Replacement, Battery: 1 단계, 이미지 1/1
    • Ensure your device is powered off before starting.
    • Flip the laptop over and remove the ten 10 mm Phillips #1 screws securing the back panel.
  2. Asus Q502LA-BSI5T14 Motherboard Replacement: 2 단계, 이미지 1/1
    • Carefully insert a plastic opening tool under one corner of the back panel.
    • Slide the tool along the seam to gently pry the panel up and away from the device.
  3. Asus Q502LA-BSI5T14 Motherboard Replacement: 3 단계, 이미지 1/2 Asus Q502LA-BSI5T14 Motherboard Replacement: 3 단계, 이미지 2/2
    • The battery is the large L-shaped block.
    • Remove the five 5.5 mm Phillips #1 screws securing it.
  4. Asus Q502LA-BSI5T14 Motherboard Replacement: 4 단계, 이미지 1/2 Asus Q502LA-BSI5T14 Motherboard Replacement: 4 단계, 이미지 2/2
    • Using a plastic opening tool, lift the battery straight upward to remove it.
    • There are a series of eight small wires connecting the battery to the motherboard. Make sure you gently lift the battery straight up to disconnect these wires and prevent damage.
  5. Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: 5 단계, 이미지 1/2 Asus Q502LA-BSI5T14 Motherboard Replacement, Motherboard: 5 단계, 이미지 2/2
    • Remove the four ribbons connected to the motherboard.
  6. Asus Q502LA-BSI5T14 Motherboard Replacement: 6 단계, 이미지 1/2 Asus Q502LA-BSI5T14 Motherboard Replacement: 6 단계, 이미지 2/2
    • Disconnect the five wires attached to the motherboard by pulling gently. There are three thin wires in the upper left corner.
  7. Asus Q502LA-BSI5T14 Motherboard Replacement: 7 단계, 이미지 1/1
    • Remove the two 5 mm Phillips #1 screws attaching the stabilizer to the motherboard
  8. Asus Q502LA-BSI5T14 Motherboard Replacement: 8 단계, 이미지 1/1
    • Remove the four 5 mm Phillips #1 screws around the perimeter of the motherboard.
  9. Asus Q502LA-BSI5T14 Motherboard Replacement: 9 단계, 이미지 1/2 Asus Q502LA-BSI5T14 Motherboard Replacement: 9 단계, 이미지 2/2
    • Remove the six 5 mm Phillips #1 screws securing the silver plates to the motherboard.
    • Open the laptop approximately 1/2" to loosen the hinge and release the motherboard.
  10. Asus Q502LA-BSI5T14 Motherboard Replacement: 10 단계, 이미지 1/1
    • Gently lift the motherboard out and away from the laptop.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Mary Kounelas
회원 가입일: 09/25/17
715 평판
안내서 5개 작성하였습니다
USF Tampa, Team S4-G1, Eyestone Fall 2017 USF Tampa, Team S4-G1, Eyestone Fall 2017 회원
USFT-EYESTONE-F17S4G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 21
전체 시간: 1,634
