주요 콘텐츠로 건너뛰기
Asus Q503UA Battery Replacement
필요한 것
  1. Asus Q503UA Battery  Replacement, Battery Replacement: 1 단계, 이미지 1/1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA Battery  Replacement: 2 단계, 이미지 1/2 Asus Q503UA Battery  Replacement: 2 단계, 이미지 2/2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA Battery  Replacement: 3 단계, 이미지 1/3 Asus Q503UA Battery  Replacement: 3 단계, 이미지 2/3 Asus Q503UA Battery  Replacement: 3 단계, 이미지 3/3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
  4. Asus Q503UA Battery  Replacement, Battery: 4 단계, 이미지 1/1
    • Remove the five screws holding the battery in place using a Phillips #0 screwdriver.
    • Screw locations are approximate. If you find screws to be located elsewhere, please update this step with their correct locations.
  5. Asus Q503UA Battery  Replacement: 5 단계, 이미지 1/1
    • Disconnect the battery connection.
  6. Asus Q503UA Battery  Replacement: 6 단계, 이미지 1/1
    • Grab and lift the battery from the top right-hand side.
    • If all screws are removed, it should come out with no struggle at all.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Roberto Apodaca
회원 가입일: 08/26/19
342 평판
안내서 2개 작성하였습니다
Gateway, Team S1-G4, Saknee Fall 2019 Gateway, Team S1-G4, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Great Instruction. Too bad reasonably priced replacements are no longer available new. I spent hours on the net using numerous search engines, The only new ones were in the hundreds of dollars, and who wants to buy used ones?
Don Dattler - 답글
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 15
30일 전: 37
전체 시간: 2,634
