주요 콘텐츠로 건너뛰기
Asus Q503UA-BSI5T17 Hard Drive Removal
필요한 것
  1. Asus Q503UA-BSI5T17 Hard Drive Removal, Battery Replacement: 1 단계, 이미지 1/1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA-BSI5T17 Hard Drive Removal: 2 단계, 이미지 1/2 Asus Q503UA-BSI5T17 Hard Drive Removal: 2 단계, 이미지 2/2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA-BSI5T17 Hard Drive Removal: 3 단계, 이미지 1/3 Asus Q503UA-BSI5T17 Hard Drive Removal: 3 단계, 이미지 2/3 Asus Q503UA-BSI5T17 Hard Drive Removal: 3 단계, 이미지 3/3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
  4. Asus Q503UA-BSI5T17 Hard Drive Removal, Battery: 4 단계, 이미지 1/1
    • Remove the five screws holding the battery in place using a Phillips #0 screwdriver.
    • Screw locations are approximate. If you find screws to be located elsewhere, please update this step with their correct locations.
  5. Asus Q503UA-BSI5T17 Hard Drive Removal: 5 단계, 이미지 1/1
    • Disconnect the battery connection.
  6. Asus Q503UA-BSI5T17 Hard Drive Removal: 6 단계, 이미지 1/1
    • Grab and lift the battery from the top right-hand side.
    • If all screws are removed, it should come out with no struggle at all.
  7. Asus Q503UA-BSI5T17 Hard Drive Removal, Hard Drive: 7 단계, 이미지 1/2 Asus Q503UA-BSI5T17 Hard Drive Removal, Hard Drive: 7 단계, 이미지 2/2
    • Once you opened the laptop, the hard drive is located on the bottom right from where the battery is.
  8. Asus Q503UA-BSI5T17 Hard Drive Removal: 8 단계, 이미지 1/2 Asus Q503UA-BSI5T17 Hard Drive Removal: 8 단계, 이미지 2/2
    • Use a Phillips #0 screwdriver to unscrew the four screws surrounding the hard drive.
  9. Asus Q503UA-BSI5T17 Hard Drive Removal: 9 단계, 이미지 1/2 Asus Q503UA-BSI5T17 Hard Drive Removal: 9 단계, 이미지 2/2
    • Disconnect the cable that is connected to the hard drive by lifting the edge slightly and sliding it horizontally away from the connector.
    • Remove the hard drive.
    • You may need to further remove the metal mounting brackets from your old hard drive then install them on your new hard drive before reinstallation.
결론
다른 4명이 해당 안내서를 완성하였습니다.
Orlando Garcia
회원 가입일: 08/26/19
359 평판
안내서 2개 작성하였습니다
Gateway, Team S1-G4, Saknee Fall 2019 Gateway, Team S1-G4, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 2개
Very easy to do. Directions were easy to follow.
Roxann Jackson - 답글
Does this laptop have an M.2 nvme SDD slot?
Isaias Perea - 답글
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 2
30일 전: 13
전체 시간: 1,060
