주요 콘텐츠로 건너뛰기
Asus Q503UA-BSI5T17 RAM Replacement
필요한 것
  1. Asus Q503UA-BSI5T17 RAM Replacement, Battery Replacement: 1 단계, 이미지 1/1
    • Flip the computer upside down. In order to ensure that the correct side is up, you should be able to read the sticker that indicates the serial number on the bottom.
  2. Asus Q503UA-BSI5T17 RAM Replacement: 2 단계, 이미지 1/2 Asus Q503UA-BSI5T17 RAM Replacement: 2 단계, 이미지 2/2
    • Remove the ten circled screws along the perimeter of the laptop with a Phillips #0 screwdriver.
  3. Asus Q503UA-BSI5T17 RAM Replacement: 3 단계, 이미지 1/3 Asus Q503UA-BSI5T17 RAM Replacement: 3 단계, 이미지 2/3 Asus Q503UA-BSI5T17 RAM Replacement: 3 단계, 이미지 3/3
    • Starting from the top right corner, use a plastic prying tool to separate the cover from the laptop. Use light pressure to prevent the plastic from breaking.
    • You should feel the frame coming loose. If necessary, use spacers to keep the frame from locking back into place.
    • Repeat the above step around the laptop until you are able to lift the cover.
  4. Asus Q503UA-BSI5T17 RAM Replacement, RAM: 4 단계, 이미지 1/1
    • Locate the RAM component. The RAM, in this case, can be characterized by its blue coloration and eight individual smaller black chips.
  5. Asus Q503UA-BSI5T17 RAM Replacement: 5 단계, 이미지 1/1
    • Locate the two white locking mechanisms on the left and right sides of the RAM component. Once you've located them, proceed to push them away from the RAM component.
  6. Asus Q503UA-BSI5T17 RAM Replacement: 6 단계, 이미지 1/1
    • Upon unlocking the mechanism, you should find that the component now pops up at an almost 45-degree angle. Lift it up gently and carefully.
  7. Asus Q503UA-BSI5T17 RAM Replacement: 7 단계, 이미지 1/2 Asus Q503UA-BSI5T17 RAM Replacement: 7 단계, 이미지 2/2
    • Now slide out the component gently and place it in a secure location.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Roberto Apodaca
회원 가입일: 08/26/19
342 평판
안내서 2개 작성하였습니다
Gateway, Team S1-G4, Saknee Fall 2019 Gateway, Team S1-G4, Saknee Fall 2019 회원
GCC-SAKNEE-F19S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
There is only one RAM Slot available…. right?
bryll503 - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 8
전체 시간: 1,199
