주요 콘텐츠로 건너뛰기
Asus Q504UA-BHI5T13 Battery Replacement
필요한 것
  1. Asus Q504UA-BHI5T13 Battery Replacement, Back Panel: 1 단계, 이미지 1/1
    • Ensure that the laptop is off so you do not shock yourself.
  2. Asus Q504UA-BHI5T13 Battery Replacement: 2 단계, 이미지 1/1
    • Use the T5 Torx screwdriver to remove the ten 1mm screws located around the back cover.
  3. Asus Q504UA-BHI5T13 Battery Replacement: 3 단계, 이미지 1/1
    • Remove the two rubber pads nearest to you using the metal spudger.
  4. Asus Q504UA-BHI5T13 Battery Replacement: 4 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove the two 4mm screws that are under the rubber pads.
  5. Asus Q504UA-BHI5T13 Battery Replacement: 5 단계, 이미지 1/1
    • Insert any of the plastic opening tools into the seam to separate the back cover (it is recommended to start at the corner of the hinges). If you did it right, then the cover should pop off.
    • Be careful as you may damage the tabs.
  6. Asus Q504UA-BHI5T13 Battery Replacement, Battery: 6 단계, 이미지 1/1
    • Once the back cover is removed, have the laptop facing upside down with the hinges facing toward you.
  7. Asus Q504UA-BHI5T13 Battery Replacement: 7 단계, 이미지 1/1
    • Use the Phillips #0 screwdriver to remove the five 4mm screws around the battery.
  8. Asus Q504UA-BHI5T13 Battery Replacement: 8 단계, 이미지 1/2 Asus Q504UA-BHI5T13 Battery Replacement: 8 단계, 이미지 2/2
    • Use the small plastic opening tool to remove the ZIF Connector on the right side of the battery.
  9. Asus Q504UA-BHI5T13 Battery Replacement: 9 단계, 이미지 1/2 Asus Q504UA-BHI5T13 Battery Replacement: 9 단계, 이미지 2/2
    • Remove the battery from the device.
결론
다른 6명이 해당 안내서를 완성하였습니다.
Brielle
회원 가입일: 10/02/17
205 평판
안내서 1개 작성함
USF Tampa, Team S10-G4, Thompson Fall 2017 USF Tampa, Team S10-G4, Thompson Fall 2017 회원
USFT-THOMPSON-F17S10G4
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
Anyone know where to purchase this battery. I’ve ordered off ebay only to get a non-fitting battery and have scoured the internet only to come up empty handed. Any help appreciated.
Rick Grinstead - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 36
전체 시간: 5,347
