주요 콘텐츠로 건너뛰기
Asus Q505UA-BI5T7 Back Cover Replacement
필요한 것
  1. Asus Q505UA-BI5T7 Back Cover Replacement, Back Cover: 1 단계, 이미지 1/2 Asus Q505UA-BI5T7 Back Cover Replacement, Back Cover: 1 단계, 이미지 2/2
    • Flip the device over so that the back cover is facing you.
    • Ensure that the device is turned off.
    • Remove the two 10 mm Philips #1 screws from the top two corners of the back cover of the laptop.
    • Remove the remaining eight 8 mm Philips #1 screws remaining in the back cover of the laptop.
  2. Asus Q505UA-BI5T7 Back Cover Replacement: 2 단계, 이미지 1/3 Asus Q505UA-BI5T7 Back Cover Replacement: 2 단계, 이미지 2/3 Asus Q505UA-BI5T7 Back Cover Replacement: 2 단계, 이미지 3/3
    • Use the plastic opening tool to gently pry the back cover of the laptop up. Slide the tool slowly along the edges of the back cover to pop it out of the clips holding the cover in place.
  3. Asus Q505UA-BI5T7 Back Cover Replacement: 3 단계, 이미지 1/1
    • Gently remove the cover and lift it off of the back of the device.
결론
Emma McKinley
회원 가입일: 02/14/20
211 평판
안내서 1개 작성함
University of Alabama, Team S2-G3, Bedsole Spring 2020 University of Alabama, Team S2-G3, Bedsole Spring 2020 회원
UA-BEDSOLE-S20S2G3
3 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 19
전체 시간: 783
