주요 콘텐츠로 건너뛰기
Asus Q534U Hard Disk Replacement
필요한 것
  1. Asus Q534U Hard Disk Replacement, Back Case Removal: 1 단계, 이미지 1/1
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U Hard Disk Replacement: 2 단계, 이미지 1/2 Asus Q534U Hard Disk Replacement: 2 단계, 이미지 2/2
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U Hard Disk Replacement: 3 단계, 이미지 1/2 Asus Q534U Hard Disk Replacement: 3 단계, 이미지 2/2
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U Hard Disk Replacement: 4 단계, 이미지 1/1
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U Hard Disk Replacement, Hard Drive: 5 단계, 이미지 1/2 Asus Q534U Hard Disk Replacement, Hard Drive: 5 단계, 이미지 2/2
    • Remove four screws with the Phillips #00 screwdriver.
  6. Asus Q534U Hard Disk Replacement: 6 단계, 이미지 1/2 Asus Q534U Hard Disk Replacement: 6 단계, 이미지 2/2
    • Gently lift the hard disk out using the black tab.
  7. Asus Q534U Hard Disk Replacement: 7 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver remove the four screws of the metal casing
    • Remove the hard disk from the metal casing
결론
다른 5명이 해당 안내서를 완성하였습니다.
Eric Okoko
회원 가입일: 10/19/17
327 평판
안내서 2개 작성하였습니다
UMass Dartmouth, Team S66-G6, Rockett Fall 2017 UMass Dartmouth, Team S66-G6, Rockett Fall 2017 회원
UMASSD-ROCKETT-F17S66G6
3 회원들
안내서 5개 작성하였습니다
댓글 4개
Good tutorial, with excellent explanatory photos. I think I can follow this one!
Pam - 답글
I’m not sure if they changed the design but I did not have to remove anything other than the case cover to replace the hard drive. Also, there weren’t any fasteners holding the hard drive at all. It was just laying in there and the foam on the cover held it in place. Since I was replacing it with a slightly thinner drive (SSD) I put an extra piece of foam in there so that it would be held securely. The job was only 10 minutes.
George - 답글
I have to identical versions of that model Q534U, one used daily for four years and the other one was dormant in storage as a backup.
I replaced the RAM in both and have 24 RAM now in each, and replaced the batteries in both, as the stored one was completely dead and the one I have been using showed a slight bloating.
NOW… I also bought a new 2TB SSD drive (D: drive) and cloned the C: drive, which is currently in a SABRENT enclosure, using ACRONIS (2022 Version Home Cyber Protect). I did it creating a useable clone. However, even after a BIOS drive assignment to the bootable Sabrent drive, it’s not booting and installing the C: drive.
Acronis Tech Support says I have to physically install the cloned 512 SSD drive into this laptop. I followed all your steps to make all adjustments, but the accessible and swappable drive is the D drive only and I don’t see the C: drive at all (is it on the other side?
How do I access the 512 HDD C: drive to swap out with the cloned one? Or do you know a trick that ACRONIS Tech doesn’t know so that I can clone via USB drive?
udor nyc - 답글
The bootable drive is the M.2, just get a larger M.2 and clone the original to it. I will probably put a 1TB in its place.
CSPhone -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 10
30일 전: 35
전체 시간: 6,691
