주요 콘텐츠로 건너뛰기
Asus Q534U Motherboard Replacement
필요한 것
  1. Asus Q534U Motherboard Replacement, Back Case: 1 단계, 이미지 1/3 Asus Q534U Motherboard Replacement, Back Case: 1 단계, 이미지 2/3 Asus Q534U Motherboard Replacement, Back Case: 1 단계, 이미지 3/3
    • Remove ten screws with the T5 driver.
    • Use the opening tool to carefully pry off the back case.
  2. Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: 2 단계, 이미지 1/2 Asus Q534U Motherboard Replacement, CPU Fan/Heat Sink: 2 단계, 이미지 2/2
    • Using the iFixit opening tool, gently pry the CPU fan connector out of the socket.
  3. Asus Q534U Motherboard Replacement: 3 단계, 이미지 1/2 Asus Q534U Motherboard Replacement: 3 단계, 이미지 2/2
    • Move the black cable located around the CPU fan out of the holder.
    • Remove the following 9 screws:
    • Three Phillips screws
    • Six Phillips screws
    • Make sure not to mix up both types of screws.
    • Gently pull vertically on the CPU fan/ heat sink assembly until it is free.
    • Before placing a new CPU fan/heat sink assembly, the CPU and GPU surfaces must be cleaned off and thermal compound must be reapplied.
  4. Asus Q534U Motherboard Replacement, Hard Drive: 4 단계, 이미지 1/2 Asus Q534U Motherboard Replacement, Hard Drive: 4 단계, 이미지 2/2
    • Remove four screws with the Phillips #00 screwdriver.
  5. Asus Q534U Motherboard Replacement: 5 단계, 이미지 1/2 Asus Q534U Motherboard Replacement: 5 단계, 이미지 2/2
    • Gently lift the hard disk out using the black tab.
  6. Asus Q534U Motherboard Replacement: 6 단계, 이미지 1/1
    • Using a Phillips #00 screwdriver remove the four screws of the metal casing
    • Remove the hard disk from the metal casing
  7. Asus Q534U Motherboard Replacement, Motherboard: 7 단계, 이미지 1/3 Asus Q534U Motherboard Replacement, Motherboard: 7 단계, 이미지 2/3 Asus Q534U Motherboard Replacement, Motherboard: 7 단계, 이미지 3/3
    • Disconnect the four marked cables connectors at the sockets.
  8. Asus Q534U Motherboard Replacement: 8 단계, 이미지 1/3 Asus Q534U Motherboard Replacement: 8 단계, 이미지 2/3 Asus Q534U Motherboard Replacement: 8 단계, 이미지 3/3
    • Lift the connecting ports up prior to removing the connectors.
  9. Asus Q534U Motherboard Replacement: 9 단계, 이미지 1/3 Asus Q534U Motherboard Replacement: 9 단계, 이미지 2/3 Asus Q534U Motherboard Replacement: 9 단계, 이미지 3/3
    • Remove the screws holding the hinges down on both sides of the device.
    • A pry tool might be needed to lift the hinge.
  10. Asus Q534U Motherboard Replacement: 10 단계, 이미지 1/1
    • Remove nine, 3.2 mm screws to fully release motherboard.
결론
다른 2명이 해당 안내서를 완성하였습니다.
Jacob Pauker
회원 가입일: 09/03/19
228 평판
안내서 2개 작성하였습니다
IUPUI, Team S1-G9, Hovde Fall 2019 IUPUI, Team S1-G9, Hovde Fall 2019 회원
IUPUI-HOVDE-F19S1G9
4 회원들
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 8
30일 전: 18
전체 시간: 1,962
