주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
Asus Q534U RAM Replacement
필요한 것
  1. Asus Q534U RAM Replacement, Back Case Removal: 1 단계, 이미지 1개 중 1개
    • Make sure the device is turned off and unplugged from the charger.
    • Use a T5 screwdriver to remove all 10 screws that secure the bottom cover.
    • Pull off the back cover of the laptop.
    • A pry tool may be needed to pull off the back cover.
  2. Asus Q534U RAM Replacement: 2 단계, 이미지 2개 중 1개 Asus Q534U RAM Replacement: 2 단계, 이미지 2개 중 2개
    • Wedge an opening tool under the battery's bundled cable connector, and gently pry the connector up and to disconnect the battery.
  3. Asus Q534U RAM Replacement: 3 단계, 이미지 2개 중 1개 Asus Q534U RAM Replacement: 3 단계, 이미지 2개 중 2개
    • Lift up the black tab next to the silver ribbon cable.
    • Pull lightly on the blue tabs until the silver cable is free.
  4. Asus Q534U RAM Replacement: 4 단계, 이미지 1개 중 1개
    • Use a Phillips #00 screwdriver to remove the 5 marked screws.
    • Gently remove the battery.
    • Do not bend or puncture the laptop's lithium-polymer pattery.
  5. Asus Q534U RAM Replacement, RAM: 5 단계, 이미지 3개 중 1개 Asus Q534U RAM Replacement, RAM: 5 단계, 이미지 3개 중 2개 Asus Q534U RAM Replacement, RAM: 5 단계, 이미지 3개 중 3개
    • Locate the metal RAM cover
    • Pull the metal tab on the corner of the metal cover to lift the cover from its clips
    • A pry tool may provide a better grip on small tab.
  6. Asus Q534U RAM Replacement: 6 단계, 이미지 3개 중 1개 Asus Q534U RAM Replacement: 6 단계, 이미지 3개 중 2개 Asus Q534U RAM Replacement: 6 단계, 이미지 3개 중 3개
    • While pushing out the metal clips on both sides of the RAM, lift up the RAM to release it
    • Pull the RAM out gently and bring it up from the slot
    • Make sure to pull out first and then pull the RAM up out of place
결론
다른 5명이 해당 안내서를 완성하였습니다.
작성자
7다른 기여자 명과 함께
Kyle Whalen
회원 가입일: 10/17/17
181 평판
안내서 1개를 작성함
4가이드 댓글
One question: I have this model and have determined that I have a bad stick of RAM. I have removed this stick but still have 8 gigs available. Is there another stick that I m not seeing or is this built in?
Elijah Elliott - 답글 공유
saame here must be another stick somewhere
SvGGRK - 답글 공유
There are 4, 2GB chips of ram, hard built into the motherboard. Located right above the SSD m.2 bay, and beside the copper cooling line. This model of Laptop has one RAM bay, I'm not sure how the Built in and Bay RAM work together but for all intents and purposes, just assume you are only using the Bay for RAM. @svggrk @elijahelliott
Nirlicnick - 답글 공유
This is too old but I hope someone can help me. I open the memory section just to clean all the dust accumulated there. After putting everything back laptop is bricked... Battery led is green. Power led is on but laptop is not booting. Any ideas?
Mario Venegas - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 19
지난 30일: 73
전체 시간: 8,097
